added it myself from timbergrove airbagsFactory air? or did you just add air in the rear? If so what system did you get?
what is your gear ratio? And does the air bags help a lot with stock tires and 3.21 gears? My future boat fully loaded will be pushing 7500# and truck is weighted for 8100Can’t believe I missed this thread......only mod is the timber grove air bags....tows level...tongue weight 950#, trailer + boat is at 8000#’s.
Gear ratio is 3.21. I use the truck for anything under 100 miles to tow the boat. For any longer distance or my bi-annual vacations to Florida, I rent a 3/4 ton.What is u
Thanks for the info I wud be doing 300miles one ways trips to coast and if it’s to heavy for truck I have 07 longbed 2500hd Chevy to pull it if I must.Gear ratio is 3.21. I use the truck for anything under 100 miles to tow the boat. For any longer distance or my bi-annual vacations to Florida, I rent a 3/4 ton.
The air bags are a must in my case. Tongue weight is 950lbs and the squat would be unbearable with the standard coils. I am running timber grove asam kit for the airbags and they have been rock solid on this truck and the Ram eco diesel I had before this one.
I swapped tires at 5000 miles for the nitto crosstek2 truck tires. Although the standard xl tires that come on the 20” would do fine with this weight.
Curious what your gas milage is towing that... Our travel trailer is roughly the same weight but haven't towed it yet.Close to 7.5k with trailer and fuel. 5.7 etorque with 3.21's. Towed A LOT better than I expected!
I've never bothered to hand calc towing but it's in the 9's. About what I got with my 3.5l EcoBoostCurious what your gas milage is towing that... Our travel trailer is roughly the same weight but haven't towed it yet.
Not great. Like 10mpg!Curious what your gas milage is towing that... Our travel trailer is roughly the same weight but haven't towed it yet.
I finally got a picture of the new truck with the boat.Last three of my five boats. Need to snap a photo of the new Ram pulling the last one I bought this last Summer. View attachment 21981 View attachment 21982 View attachment 21983
Ok, so I'll plan on like 8mpg with the 3.92 lolI was getting 10.8 mpg towing my boat which is about 6500 lbs, and I have the 3.21 gears
See post #67.Anyone towing a nitro z21 or something similar with the 3.21?
It is. This is my first boat so I didn’t know if anyone had any infoSee post #67.
You'll be fine pulling that lightweight. It only weighs about 4,000lbs doesn't it?
If my boat weight fully loaded and trailer is 7700lbs what weight lb hitch will I need?
