Rampat
Fishing opener in MN this weekendView attachment 24614
Looks great. I see you have air-ride. What level are you on in that picture? Looks like you at least have a level
Thanks, this was in normal level and no level links either. The 295/60's help the look though!Looks great. I see you have air-ride. What level are you on in that picture? Looks like you at least have a level
They're Toyo Open Country a/t, I switched them after a couple hundred miles of owning the truck and didn't notice anything different on ride, MPGs of usually around 13 or so.For sure! I have the same truck with no air ride and want to upgrade tires. Same rims as you too. What brand tires are they? How different is the ride and mpgs since switching?
i have air bags to help with that.Looks great man. I’m impressed that there really isn’t any noticeable squat with that lift.
What kind of towing setup did you use? Air suspension? Bags, WDH?8000lbs towed fine .
The lift makes the truck level it sags in the back when towing so i bought timbergrove airbags and installed them myself.Added airbags with the lift?
Its getting the same MPG as my 3rd gen I had with 3.92 gears and 33's , I only have 3500 miles on it (took delivery in Sept) so I would think the MPG will continue to get a bit better.****. I was hoping they wouldn’t do that. I’m averaging 16 over the 2500 miles I have on my truck. It’s steadily climbing too. Hoping to get near 17.5 after my oil changed at 5k
Plus your son another 75 LbsCan’t believe I missed this thread......only mod is the timber grove air bags....tows level...tongue weight 950#, trailer + boat is at 8000#’s.
	Factory air? or did you just add air in the rear? If so what system did you get?i have air bags to help with that.
What kind of fuel economy do you get with the 3.5" lift and 35" tires?Not a great pic but at least it’s clean. Just got the boat out of storage.
I average about 15.5. Never get over 17 and towing is 9-11.What kind of fuel economy do you get with the 3.5" lift and 35" tires?
