Extremely sharp
Waiting a couple years to see them get square with the new Cummins engines with the CP4 integration.
The one pictured appears to be a 392. I'm getting 15.4 average over the first 7000 miles. I too like the looks, but not everyone does.
If you do that’s all that matters
yep, like mine and the mpg are better than i expected ... towed the 9,000# 5th whl camper home just fine, B&W hitch, ... View attachment 29349
IF you think that is long you should see it with the 33' 5th whl connected .... really it is the same size as my 2005 Dodge Big Horn 4 dr with the 8' bed ... after all this is a trk bought to do trk things not a parking lot queenWow that's sure one long truck
some new pixs with running boards, mud flaps,cb antenna and B&W (poor pix)
nope, here is where i got mine for the Ram 5th whl prep ...I like that setup.
I thought the Companion only worked with the Turnover ball gooseneck hitch? My F-250 had a different gooseneck hitch so I added a Draw-Tite 16k on rails. I hated that setup, but it was done at that point (too many holes in the bed to change). I always said that if I did it again, I would do the Turnover gooseneck with the Companion 5th wheel. That said, this was before 5th wheel prep on stock trucks was a thing.
I really like that it fits under the tonneau cover.
