Wickedsaint
That looks so good and badass! What was the process like? Or did you have it professionally done? Cost?
Had the shop spray it when they did the bedliner. I believe it was an additional $150 because since they had to take it off, prep it, and reinstall. If I was not getting the bed done at the same time I would probably just have pulled it myself and had it powder coated. If you want quick, easy, and cheap, I rattle canned the grille on my 510 in satin black. It has held up alright for 10 years however it is due for some TLC. Also I make it a point to avoid going offroad in it.
ramButz
syracuse,ny
  • Rigid_Industries_D2_-_Wide_-_Set_of_2_ad34136e-c4b5-45af-8ea0-b946a550109e.jpeg
Rich B.
Put on the rear wheel well liners. Glad I ordered extra screws. The Bighorn doesn't have fender flares which means you will need 4 extra screws per side. The video that showed how to do this was on a Laramie which only needed 1 extra screw per side. Anyways, looks a lot better with these on!
Wakesnowb
Do the cargo lights come on in reverse? Would the new LED lights be too bright for people behind you when braking or reversing?
Installed High power LED's - Cargo light- Much brighter than the standard bulbs that came with the truck
PorBoy
Millville NJ
View attachment 21637 View attachment 21638
ramButz
syracuse,ny
Those aren’t the ones I have. They look even smaller so I can’t inagine you'll have a problem. Depends on where you mount them but if you have the senslip like i do you should be good
YEA!! thanks "patsy"...p.s my wiring harness just arrive.soon when the weather gets better i will post! (y)
PorBoy
Millville NJ
Mine is as basic a Laramie as they make. If not for my wife I would readily be rocking a BigHorn and be happy at that.
Rampat
Boca Raton, FL
The only Laramie’s that come with the wheel well liners stock are ones with the air ride suspension. They might come with ORP too but I am not 100% sure.
ramButz
syracuse,ny
i install this last week."PedalCommander".so far no codes as of yet.i have it set to "City1"cant imagine how dramatic the other setting are like. :eek:.when it goes up a hill...watch out!!but that is the main(or one of the)reason i got it.seems like when i installed my "borla"muffler.now i get all kind of challenges.from "SubCompact" to "soccer mom"suv's.trying to race me up the hill.....Go figure:confused:...oh P.s had trouble getting it in focus..sorry:cry:
NordicNevs
Got the new hitch by WeightSafe
Specs:
2” shank
4” drop
1500lb max tongue weight
2” ball 8000 max
2-5/16” 10000 max
Ordered from amazon. All my other hitches were for my diesel and held a 2-1/2” shank. Pity because I have $600 in hitches I can’t use.
Anyway I really like it. Easy to use.
Wakesnowb
They do not come with ORP, must purchase separately. I got mine through my custom order.
Rampat
Boca Raton, FL
Which Borla did you choose? How do you like it so far?
  • Top
