Finally installed tow hooks and bezels. Not hard but u need to know that the existing bolt is torqued to Max and has a retaining clip that requires you tap out so I can remove for re-use.
Installed This
How was the install? I have one sitting in my center console as we speak.
I have the same on as Nick54... It's pretty easy but prep is important especially with such a large screen. Once clean I used a flashlight at an angle to make sure it was perfect before applying the protector.
I installed mine and the install was super easy. My recommendation is as follows:
1. Clean the screen with an alcohol wipe very well
2. Wipe the screen with a micro fiber cloth
3. Reclean with alcohol on a micro fiber towel
4. Using a can of compressed air, blow all "dust" or particles off the screen
5. Place the suction cup in the upper right corner and practice having the very bottom of the protector lean against the bottom black plastic frame around the radio
6. Use the compressed air one more time and then peel back the film protector from the glass
7. Gently rest the bottom on the black frame and then slowly allow the screen protector to adhere to the touchscreen
If done properly, you should get no air pockets. If you do, VERY GENTLY use your fingernail to pull the glass away from the radio and reseat the glass screen protector where the air pocket is. If you pull it too hard, it will crack.
I’ve been waiting for someone to do the flag. I might do the same. Looks good. Do you have a link?
Yeah , what Patsey said, I bought on EBay 23.00. I tried copying link but I am electronically challenged I guess ,because I can’t get it to work. Just search 2019 Ram grille American flag decals.
Found it guys, thanks.
Took it to the auto show. Ram defiantly had the largest crowds.
stunning trucks
stunning trucks
What with the truck with all that chrome on the larger grill?
Easiest ever! Clean and dry, little suction cup is super helpful for handling and indexing the upper right corner. Once it touched the screen, it sucked itself to the screen, no squeegeeing necessary.
Took it out on the beach for the first time - Montauk, NY. Popped it into 4H, didn't take any air out of the tires and it rode beautifully, smooth and consistent, no slip or spin. Best truck I've taken on the beach from street to sand so far and I've taken Fords, Chevys and Jeep Wranglers.
MVIMG_20190406_190213.jpgMVIMG_20190406_190438.jpgMVIMG_20190406_190324.jpgMVIMG_20190406_190224.jpg
Took it out on the beach for the first time - Montauk, NY. Popped it into 4H, didn't take any air out of the tires and it rode beautifully, smooth and consistent, no slip or spin. Best truck I've taken on the beach from street to sand so far and I've taken Fords, Chevy's and Jeep Wranglers.
View attachment 21502View attachment 21503View attachment 21504View attachment 21506
Beautiful! Really a great shot with the morning sunrise on the side. The tonneau looks great too. Best of luck with it. Have you pulled the trailer yet?
