I saw them as well but I liked the way the Superbrightled.com device works far better and, being an engineer, I have everything I need to install it professionally. For a novice just wanting a flashing bulb, this is a good solution but not as robust IMPO. Thanks for sharing!
I know i used the flasher too. they have a better flash pattern. I was just giving an option for peeps that didn't wanna cut wires :)
How much was the ceramic coating
For abuff, polish and ceramic coating, it was about $850. I would probably recommend doing a second coating on it which would be an additional $400, however, I have started using a product called bead maker and it is INSANE how much smoother the coating is afterwards. It helps the ceramic coating to last a little bit longer than it normally would.
https://www.theragcompany.com/p-s-bead-maker-paint-protectant-pint-16-oz/
https://www.theragcompany.com/kit-2...pint-p-s-bead-maker-five-orange-eagle-towels/
Here is a video on it.
If you don't end up doing a ceramic coating, at least do the Bead Maker once in awhile. You will be blown away with the results.
Finally swapped those UGLY hooligan bulbs from the third break light to 1500 Lumen LED's. BEA UTIFUL
Which ones did you go with? I want to do the same but I wanted to get good quality.
I could not find a high quality lug nut that I actually liked. If our wheels had recessed holes for the lug nuts I would have used Pro Comp or the like in a splined lug nut but ours are exposed. I bought inexpensive eBay nuts. For $33 I can replace them again if they chip and rust. If you find a quality set that also looks good, please PM me and I will buy them so we know.
https://www.ebay.com/itm/24-Pc-2019...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
https://www.ebay.com/itm/24-Pc-2019-DODGE-RAM-1500-BLACK-OEM-TYPE-SOLID-LUG-NUTS-14x1-50-1709DBK/392122246552?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
That works, maybe they will hold up nicely. If I find a quality product I will certainly let you know.
AFE Magnum installed a month ago and was looking at the AFE CatBack but sadly i tore the sidewall of my 22" less than 2000 mile front passenger tire. Of course warranty does not cover this and the replacement tire with mounting, balancing and tax put me back $293 today. Took 3 days to get the tire into the Goodyear dealer but at least I am back running now.
Sheared a bolt in half while installing GoRhino Dominator D6 running boards. Hopefully the warranty team will get back to me with a new bolt and bracket? I hope.2131721318
  • jl13
