Black Rims/Tires Pictures
PorBoy
Millville NJ
That’s funny as I have another new set sitting in my garage. I’m waiting on oem TPM sensors before I have them put together and mounted. Should be here on Monday.... 53DE294C-D4B7-4314-842F-0A3E7F4149DB.jpeg
ksn240
Yeah my whole vision of the truck changed. Bought wheels. Then bought fender flares, then had to buy wheels again because they were tucked in too far.
ksn240
To this...
Then installed fender flares...
Then finally just installed new wheels and tires that match better...
Looks much better now. That is a 305/55r20 tire on 20x10 -25 offset wheel.
PorBoy
Millville NJ
Are they the same wheels, just wider ? That set up looks very sharp...
Rob3989
20x10 -18 35x12.50
Runningwithbeers
I came across American Outlaw Gambler wheels while looking at 20" options but I wasn't sure if either wheel would work for the Ram. Here are the two sizes that are listed in 6x139.7 bolt pattern.
126-2084GB20x106x139.7-18106.20 bore250043
126-2983GB20x96x139.718106.20 bore250041
ksn240
Either option will work. The bottom one will fit identical to the stock wheels. The top option will stick out about 2" further than stock.
BlackSunshine
Stock, but they are black. :unsure:
Runningwithbeers
KNS240 were you happy with the American Outlaw Lonestar wheels quality wise when you were running them? I'm thinking about pulling the trigger on the 20x9 gamblers I like the old school semi circle arches plus Mass can be a PITA inspection wise on tires sitting proud of the fender so trying to stay tucked in if not flush for less headaches.
Take it easy
Jay
PorBoy
Millville NJ
I looked on their site a couple of weeks ago and saw a set of wheels in 20” that I liked. I would want to unload one more setof my wheels before bringing in a new set lol. AFDD1221-4702-4CE3-BA29-13E8931A39D5.jpeg
ksn240
Take it easy
Jay
I was absolutely happy with them. I wish they would have had those wheels in a 20x10 -24 and I would have bought them again. Quality was great on them.
Webbd30
275/65R20 +1 offfset
Nitro ridge grapplers on air bags = Cadillac ride quality and sexy *** stance and appeal.
SB89
ksn240
What size did you go with before you changed it a second time? Ridge Grapplers?
The first set of wheels I put on 275/65r20 BFG KO2s. Now I have on 305/55r20 Atturo Trail Blades and have been impressed by them.
SB89
Air suspension? Level? any rub?
ksn240
Coil suspension. 2" Readylift level with UCAs. No rubbing at all. I did already take the mud flap off though because it had to come off to install my flares. May or may not make a difference. I have about 1/2" clearance.
