Black Rims/Tires Pictures
Got the gamblers in today hopfully this weeknd I can get the flaken wildpeak A/T3Ws mounted on them.
Just got these put on this week
Here we go..
^^^. Definitely adds beef paired with those fender flares..
Thanks I'm debating wrapping a portion of the front bumper black leaving the beveled edges for the light pokets in chrome and the lower middle section in chrome.
Close enough black?
May I ask what gears your running? Was there any rub with those tires? How much did mpg drop from factory tires? I really like those tires and would like to get those.
Went from this...View attachment 20023
To this...
Then installed fender flares...
Then finally just installed new wheels and tires that match better...
Looks much better now. That is a 305/55r20 tire on 20x10 -25 offset wheel.
What brand and size are the first set you added? How much bigger are the second? Have you noticed a difference in ride and mpg between them? Any lift/level?
The first set of tires were BFG KO2s in 275/65r20. Basically a 11" wide by 34" tall tire. Gas mileage was pretty close to the same as stock once I corrected the speedometer.
The second set of tires that I am currently running now are Atturo Trail Blade XT. They are a hybrid AT/MT tire. Size 305/55r20. These are 12.5" wide by 33.5" tall. Gas mileage again is about the same. On the highway I am averaging about 18 mpg, but that is running 80 mph. If I baby it I can get over 20. I have been impressed with the Atturo tires. I went with them because my wife was ready to kill me buying new wheels and tires for a second time. Figured I would try them out and save a little bit of money, especially since I am considering a 6" lift and will be switching to 35s when I do. That will be sometime next year if I do it. They perform well and ride pretty good, just a little noisy. I usually have my radio up anyway though so it doesn't bother me between that and my Carven exhaust.
The ride is still pretty good. A little stiffer just from going to a 10 ply tire, but still smoother than my 4th gen.
I'm running 3.21 gears, no rubbing, and a 1-2mpg drop
24” Luxx 10 rims on Atturo tires
