Black Rims/Tires Pictures
Man. That has the be the best one I’ve seen! What kind of gas mileage do you get with the lift and bigger tires?
I appreciate that very much! I've only been on them since late tuesday and reset my average mpg early the next morning. I've put prolly less than 100miles on them and thats all city, bunch of lights, stopping and starting. I'm averaging around 15mpg at the moment, but i'll get a better reading here in the next week or so once i put more miles on it!
How much cutting did you have to do?
Not very much but the place i got it done at also took some of the black plastic off for me. I need to get some pics to show where and what i trimmed when i get a chance. I took the front wheels off just to make it easier to get to and trim up. I dont want anything to look like its not suppose to so i take my time in doing it trying to make it look like its meant to be. Overall time wise i prolly spent 2hrs doing it, beer breaks here n there included :cool:
I really like that setup. Nice pics.
Hey just wanted to double check with you that you have had 'zero' rubbing issues with your truck. I'm going to do the new Fuel Shok 20x9 with a +1 offset and would probably switch to the +20 offset if you did. Im gonna run the Toyo RT 35x12.5x20...I think they're basically the same dimensions. Thanks
I have zero running issues. I needed to go +1 from the stock +19 to clear the UCA’s on the ReadyLift Kit. If anything you would want to go negative offset but was told there might be rubbing issues on the fender/wheels wells. I don’t think you would want to go +20 or you will need spacers.
Oh wow! I was thinking the opposite and that I would be better going more more of a positive offset... I plan on installing the Readylift kit as well because it doesn't look like BDS 4in will be ready...dumb question....The truck in the Readylift video is on a stock ( +19 offset) did they have to use a spacer?
From the ReadyLift site for the 3.5 inch kit.
https://www.readylift.com/3-5-sst-lift-kit-2019-ram-1500-4wd-1.html
The 69-1935 SST lift kit provides 3.5" of front lift and 2" of rear lift. The 2019 Ram now comes with a composite upper control arm with a sheet metal cover. Our engineers determined the the best kit solution would be to include our DOM tube steel upper control arms with corrected ball joint angles. The lift is delivered by way of CNC-machined billet aluminum top mount strut extensions and spring pre-load spacers. This combination generates a true 3.5" of front lift which is perfect for installing up to a 35" tall tire on a 20x9 inch wheel with a 0 offset.
Man...Im glad I reached to you...Cheers!
18in Raceline defenders -12 35x12.5 bfg at's cst 4 inch spindles on the front stock rear
Just got these on and taken right after the install. Sorry for the bad pics... only open area in the lot and the sun wasn’t in my favor lol. Will post more when it’s all washed up.
295/60/20 Ridge Grapplers
20x9 0 offset Hostile Fury
1 inch level up front with homemade links
Here are Fuel Hardline 18"x9" +1 on a Rebel with the OEM Goodyear Wrangler Duratrac 33" tires with white letters turned in. Moves tire outboard about 1" A couple of pics are with air suspension in lowered entry/exit mode that make truck look kinda sinister. You can't drive it that low for more than a few mph as it senses speed and will raise back to normal height.
My contribution
Let’s see if mine will show up.
