Busy day. Installed the Mopar mud flaps, VLED reverse light LED's and radar mounted. Still working on the black emblems. RAM HEAD on the tailgate was a PITA to remove and to get the adhesive out.
^^^. Do you have a performance or bodyshop near you ? I’m sure either one will also be capable if you are not feeling the dealership.
Do you have any pictures from the front or back? I have the same level kit and I am looking at Nitto Ridge Grapplers in 295/60/20 or 305/55/20. Not sure which one to go with yet. Thank you...
20062
20063
Nice! Where did you find the door strike cover?
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 003521 miles.
Well looks like my endeavor for a gear swap is in vein
Have to do the front gears at the same time (obviously) well moes says no housing is on the market for a front gear swap
Sooo if you got the 3.92 from the factory you did it right. No options out there to convert which sucks.
Got my power steering recall fixed - just had to torque it.
Parts arent in for the brake pedal recall
They ordered my parts for the brake squeal maintenance bulletin
Question: has anyone installed a side step on the REAR of the truck? Something like the Bully single steps, but not on the side - need it on the rear to get into the bed easier201146F844F41-6E63-4B4A-9E4C-3AD7E0FE05B2.jpeg
Thanks for the update NordicNevs
Finally installed the VLEDS license plate frame reverse light today.
Mud flaps or bed lighting kit is next. Can’t decide which....but I’m also looking to upgrade tires. And do a leveling kit.
Oh boy....these trucks are addicting.
Question: has anyone installed a side step on the REAR of the truck? Something like the Bully single steps, but not on the side - need it on the rear to get into the bed easierView attachment 20114View attachment 20114
Have you looked at the Smittybilt beaver step, fits in the hitch opening. I have it on mine.
Post # 20 shows it.
