GM convert
- Apr 8, 2018
Want to do a mirror tap for radar detector. Did you take any pictures of mirror disassembly? What kit did you use?Awesome. Thanks!
It’s done. It’s a pain. The two wires you tap are the black ground and red next to it. I used blend mount wire kit 15 inch and their mount.
line it up about 45 degrees off center then while pushing it against the windshield twist it back to center. it feels weird and will want to pop back out but as long as you put pressure it will snap back into place.I got the mirror off, it is some sort of clip over a bolt on my long horn. Anyone know how to get it back on???
Yup, thanks!line it up about 45 degrees off center then while pushing it against the windshield twist it back to center. it feels weird and will want to pop back out but as long as you put pressure it will snap back into place.
i used some non marring tools from Harbor Freight. Its a little tough but apply enough pressure and that piece will come off. Good LuckCan anyone shed some/tips on how to remove the lower trim piece with the four metal clips? I was able to remove the upper trim but cannot get to those metal clips to set loose.
Thanks for the quick response! U applied pressure how and where? Just from the top like the upper trim piece? I remove that one prying from the top with a plastic trim tool. Sorry to keep asking. Just do not want to break it.i used some non marring tools from Harbor Freight. Its a little tough but apply enough pressure and that piece will come off. Good Luck
Thanks! Yes I ahem already removed that center section, just in the manner you describe. I am asking about the bottom/base section that is in contact with the windshield. That is the one I am now trying to remove.You need to pry that center section out from the headliner area towards you as there are two tabs at the base that will beak off if you try to pull it out from the mirror stalk. There are pics of this piece in this thread I believe to show you where the tabs are.
See post #23
