2019 ram key fob roll windows down?
Dusty1948
Rochester, New York
My 2010 Ram had it. My 2014 and now the '19 does not.
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 002491 miles.
PorBoy
Millville NJ
Nope it was laid to rest, although you can have it done via the aftermarket.
Neurobit
RAM Sorcerer
Texas
I'm glad it doesn't have this 'feature'...
I carry the fob in the watch pocket when wearing jeans, and when sitting down it tightens the fob, and the buttons can activate the windows
I've had this happen on my BMW a couple of years ago while having dinner with the family. Came back to the truck and the sunroof, and windows were all open during a torrential downpour... It happened on another occasion but fortunately it wasn't raining.
Not good... :O
Laramieguy
How about auto folding mirrors? My buddy's Grand Cherokee has that feature. When he turns the car off the mirrors auto fold in without pushing the button.
PorBoy
Millville NJ
Lol neither my 2018 fully equipped Accord nor my Ram offer this feature. At least I can push a button with the Ram. :)
ian.defilippo
This was deemed unsafe (for sum people). And it is programmed into bcm need a flash tool like Alfaobd to unlock. Or a cool dealer will do this for you. I bought the flash tool for my 2015 and had this option, I heard all years had it. Flash tool can change tire size for correct Speedo and tpms pressure sensors limit change, and that is just the tip of the burg. Any thing programmed and not on (DRLs) can be flashed with this tool 120$.
ClancyO
Hendaerson, NV
Does alfaodb work with the new 5th gen ram? All the links google showed me were 4th gen and earlier..
Brandon_Vickers
From their webpage:
"Note: Starting from MY2018 FCA bults in the Security Gateway Module (SGW) which blocks access to diagnostics for the third-party software. There is no software solution yet, as a workaround please use a hardware bypass module (as an example). "
Ken2021Etorque
Yes you can activate such feature, i have 2019 Ram 1500 Classic and used the alfaobd, obdlink bluetooth and bypass harness was able enable drl, change tire size, global window down, program 7" evic with miles, idle and driving hours
Sent from my GM1915 using Tapatalk
mike_ct
Did you enable global down in bcm or was there other options to enable to make it work? Door module setting? I was trying on my 19 with alfaobd, got other things working, no global down.
how about global up?
Ken2021Etorque
With alfaobd under global down
Ken2021Etorque
Here is a pic of menu
