Saw that. Many thanks!!!Done did it. ;-)
No work around for the electric e-brake release when your truck doesn't have power, but like I said, fix the reason the truck won't start and the brakes will release themselves. They wanted to take me out and show me how to uncheck the auto brake setting in the Uconnect. I told them I could handle it. Will probably never EVER use that feature again, EVER. We'll see if the 2020's have a work around.
I was at my dealer this morning hoping to get the power brake pedal recall (VO7) and no luck-no parts--but I asked him if I lost all power completely, could I get the auto brakes to release. He said they had to do that a couple of times. I am old so he took a picture of the back brakes on the back side of the rotor and there is a green wire coming to a top of whatever it is and he said they had to unbolt that and pull it out on each side (Yeah, this is not tech language and I should have had him take a picture for me--but maybe you all know about this ---or maybe I am not answering the right question--but trying)
Sounds like you may be onto something, because I do know there are electric motors on each of the rear rotors. Although it sounds like something I wouldn't want the tow truck driver attempting without some training and guidance.
Electric brake wont release on my truck and i have power but a yellow parking light on the dash. Trying to figure out how i can release it . Doesnt seem there is a way.No work around for the electric e-brake release when your truck doesn't have power, but like I said, fix the reason the truck won't start and the brakes will release themselves. They wanted to take me out and show me how to uncheck the auto brake setting in the Uconnect. I told them I could handle it. Will probably never EVER use that feature again, EVER. We'll see if the 2020's have a work around.
There is a way to release the parking brake. I just did it, but it does take some time and tools. Have to take off the two T30 bolts holding the electric brake hub on the rear calipers then you’re able to turn the brake with a 12pt 10mm wrench. Makes it a lot easier with the tire off.Electric brake wont release on my truck and i have power but a yellow parking light on the dash. Trying to figure out how i can release it . Doesnt seem there is a way.
Hopefully you are not out in the middle of knowhere if this happens . I turned off mine ,autopark in Uconnect.There is a way to release the parking brake. I just did it, but it does take some time and tools. Have to take off the two T30 bolts holding the electric brake hub on the rear calipers then you’re able to turn the brake with a 12pt 10mm wrench. Makes it a lot easier with the tire off.
It’s
