Zero offset?
I may have to look into that. The whole offset thing throws me for a loop a little. I wonder if the +22 and the .5 extra width would move the wheel in enough to cause rubbing during steering?
only 9mm closer to control arm and 3mm further out which isn't a whole lot. I doubt you would need to worry about it.
9mm is almost 3/8". When we only have about 1/2" of play it's a whole lot considering flex of tires/suspension when turning.
Guy on this site, forget name is running 9.5 +20 so I highly doubt the extra 2 will matter and he's lowered.
Another, but stock
"Needs no trimming and it rubs." Doesn't specify what it rubs on. May just be cause he's running 305 tires so a little wider than stock.
Wheel well liner which is what they usually rub on ( heat gun fix ), plus he's not off-roading, so I doubt any worry for suspension flex since wheel and control arm move together.
