CHeYeNNe71
- Aug 11, 2023
Almost definitely.I may have to look into that. The whole offset thing throws me for a loop a little. I wonder if the +22 and the .5 extra width would move the wheel in enough to cause rubbing during steering?
only 9mm closer to control arm and 3mm further out which isn't a whole lot. I doubt you would need to worry about it.I may have to look into that. The whole offset thing throws me for a loop a little. I wonder if the +22 and the .5 extra width would move the wheel in enough to cause rubbing during steering?
9mm is almost 3/8". When we only have about 1/2" of play it's a whole lot considering flex of tires/suspension when turning.only 9mm closer to control arm and 3mm further out which isn't a whole lot. I doubt you would need to worry about it.
Guy on this site, forget name is running 9.5 +20 so I highly doubt the extra 2 will matter and he's lowered.9mm is almost 3/8". When we only have about 1/2" of play it's a whole lot considering flex of tires/suspension when turning.
"Needs no trimming and it rubs." Doesn't specify what it rubs on. May just be cause he's running 305 tires so a little wider than stock.Guy on this site, forget name is running 9.5 +20 so I highly doubt the extra 2 will matter and he's lowered.
Wheel well liner which is what they usually rub on ( heat gun fix ), plus he's not off-roading, so I doubt any worry for suspension flex since wheel and control arm move together."Needs no trimming and it rubs." Doesn't specify what it rubs on. May just be cause he's running 305 tires so a little wider than stock.
