If you tow anything I would go with the 2". Unless you want a little bit more height go with the 2.5" but it will be pretty much level so you might have to add a spacer in the rear.I really like the look @moosem I am planning on using pucks as well. Not sure if I should go with 2" or 2.5"
I’m having a really hard time deciding if I should do the motofab 3” front/ 1” rear with my readylift UCA’s instead of the 2” level.If you tow anything I would go with the 2". Unless you want a little bit more height go with the 2.5" but it will be pretty much level so you might have to add a spacer in the rear.
I ended up ordering the Eibach pro-truck kit because of the reason I mentioned in the above quote and the fact that I like all the Eibach lowering springs and shocks I’ve tried so far. I’ve abandoned the spacer idea.Looks like 5100s are back ordered at all the places that seem legitimate.
Wait, people use the bed? It’s not just for good looks!?!My 2" motofab give me a 1/4" of rake 2.5 would be nose high and be obvious with weight in the bed
Yep, pool chemicals, no way I would put gallon jugs of chlorine or bags of salt, in the back seatWait, people use the bed? It’s not just for good looks!?!
Disagree. I don't like the Cali reverse stink bug look or the stock stink bug look that has 2" of rake. 1/2" of rake is the perfect look.Jesus people ….1”-1-1/2” of rake, or you look Cali drag *** low …. And that’s just stupid
Cool. I’ll go with 2” pucks and no UCAs hopefullyMy 2" motofab give me a 1/4" of rake 2.5 would be nose high and be obvious with weight in the bed
You say that now… Then you’re a few beers in and order $1200 worth of suspension and you’re blaming @Whoa_Ram for it.Cool. I’ll go with 2” pucks and no UCAs hopefully
HAHA it's so hard to keep things stock while there are so many great things you can do to it. Once you get your shock kit and give a review, I'll probably be ordering mine and blaming you LOLYou say that now… Then you’re a few beers in and order $1200 worth of suspension and you’re blaming @Whoa_Ram for it.
