Truckone176
- Nov 1, 2021
Ok, I've read and re-read all of the lowering threads that I could find concerning a 2021 1500 Laramie. My truck does have the factory 22" wheels so the Belltech spindles will not work, but I would consider swapping out the wheel bearings if the drop spindles are that much better or a lowering route. I was also considering the Maxtrac kit with the adjustable upper control arms just to get the alignment within factory specs. As far a the rear, I would assume that coils and shocks with an adjustable panhard bar is the route to go and that either company are about the same? So the biggest question after all of this, would it be worth changing the wheel bearings out to get the spindle lowering kit, or use the Maxtrac kit as I do not want all of the trouble that seems to be with the Belltech kit. All in all, I want a 2/4 lowering.
