Does anyone know where each of the wires go specifically.  The manual is terrible for this.  I did not have a wire in pin 45 on the C5 connector, so I just plugged that in.  Although it is possible I am on the wrong side connector.  I also had to splice the red wire to the large red wire at the top of the C3 connector on the pdc.  I did not think this was pin 9, but there was no pin in the port that I thought was pin 9, and the red wire came with no connector.  I figured that was less important as long as it is getting power somehow.  My charging pad is not turning on though, so I must have at least one of them in the wrong spot.  I am going to post a photo once I get this figured out since this was so frustrating.  Also, can anyone confirm if this needs to be activated or not. I am assuming no, since it is not in the directions, but just checking in case that is why it is not working. I am not seeing the blue light on the front the pad.  Any help with this would be very much appreciated.!
