Will 35x12.5 General Grabber ATX fit on Rebel
rossvdm3
Hey guys,
Just bought a 2023 1500 Rebel and wanted to know if 35x12.5 General Grabber ATXs would fit (with some trimming). I'm looking at the 18 inch KMC542 +0 rims. This tire/wheel combo was chosen to keep the additional unsprung weight to a minimum while providing the look I'm aiming for. I've seen other 35s fit, but the Grabbers are a true 35 inch wheel so I wasn't sure if the wheel offset/tire size would work. Any advice would be appreciated!
For the front end lift, i'm planning on doing either:
a) bilstein 5100s (5th ring) with rough country UCA (~1.8 lift)
b) 2 inch readylift kit with UCA
biggggant
I'm on 35x12.50 with a 4 inch zone lift and my passenger inner fender liner still rubs sometimes at full lock and up an incline. I need to either re-maasge it with a heat gun or just trim it. Thats with -18 offset rims
silverWS6
EPTX
I don't know how the 0 offset will work, but you might also need to consider if the tire will rub the upper control arm.
I have -12 and I was able to fit 35x12.5 (BF Goodrich's). I had a 2 inch level and only had to remove the small "mud" flap. I've been off-roading and have had zero rub.
rossvdm3
Ended up getting take off TRX wheels/tires from marketplace...much cheaper option and kept the additional weight to a minimum. Also lots of posts confirming they do fit with some mods.
