Littlewing
- Nov 16, 2020
what trim levels come with it open and what would be the reason for it to be open or closed???It depends on the trim level of the truck. Some are open and some are closed.
finding more light was not the purpose of asking my question.... the intent of my question is "why is mine solid?"I’m curious what you need more light for. Your LED’s are already super bright. Just wondering. I see a lot of aftermarket light bars these days
Since OP talked about putting in a light bar, but then gave a rude response, I'll answer for him. I want to put a low-light condition bar there (yellow) for fog/rain/snow/dust. It'll point pretty much where the fog lights do now so it'll spread out across the road. I agree that the LED lights produce a lot of light.I’m curious what you need more light for. Your LED’s are already super bright. Just wondering. I see a lot of aftermarket light bars these days. Thanks.
Ah ok. Thanks for filling me in.Since OP talked about putting in a light bar, but then gave a rude response, I'll answer for him. I want to put a low-light condition bar there (yellow) for fog/rain/snow/dust. It'll point pretty much where the fog lights do now so it'll spread out across the road. I agree that the LED lights produce a lot of light.
OP, if you had done any type of searching about putting light bars there you'd see that people either remove the solid backing or buy a new, open grille to fit there.
Who cares ? It’s a 40 dollar part , if you want is so bad go get it . Working yourself up on trim levels for a 40 dollar item smh.finding more light was not the purpose of asking my question.... the intent of my question is "why is mine solid?"
does any one know what trim levels and why some are solid and why some are not solid???
IIRC this is only on the Rebeli remember saw a video somewhere show the lower grill is combine of 2 parts and can be remove to made it see thru, they're holding together by all the clips around it, correct me if i'm wrong.
As a new member wanting help...you may want to be a bit more considerate and think about how you may want to respond in the futurefinding more light was not the purpose of asking my question.... the intent of my question is "why is mine solid?"
We get it.....Also a new member, here, still waiting on my truck in fact. In any case, I think y'all reading too far into OP's question. I think the lightbar was more of an example of what he was asking about. If they are all solid and someone says so, then here is xx examples that are not.
winnerAlso a new member, here, still waiting on my truck in fact. In any case, I think y'all reading too far into OP's question. I think the lightbar was more of an example of what he was asking about. If they are all solid and someone says so, then here is xx examples that are not.
