Why Doesn't The Fuel Door Lock?
mikeru82
The Palouse
I'm not really worried about it since I park in a locked garage at night, and a secure parking lot at work. But there are those times when I'm at Home Depot or the grocery store when anything could happen.
vdemarco
I am confused, i just tried again, and the door is locked. pushed all the way around. I took a movie to show
Mother
Orlando, FL
Just walked out to my 2020 (9/19 build) without my key and the fuel door will def pop right open.
What's your build date? Perhaps they made a running change...
vdemarco
Mine was built 8-19. I can't explain it. Maybe its part of some option i have??
Jeffjad
Southwest PA
I am sure you have fueled your truck many times and I am not trying to insult you by any means but I have to push pretty hard on mine. IMG_20200619_133537.jpg IMG_20200619_133544.jpg What does the inside look like? Here is pic of mine
Biga
Cincinnati
Push in on the right side you have to push in pretty far and let go quickly and it should release.
vdemarco
You are right i am sorry about the mess up. I just never pressed hard enough.
geebee1954
Manual? This thing has a manual?
Mine (2020 Warlock) has the manual in the screen under Apps. Gives me something to look at when the boss lady is in a shoe shop for hours on end. Search facility sucks though.
Neurobit
RAM Sorcerer
Texas
:LOL::LOL::LOL:
Very true...
Amerinamese
Geno's Garage makes a locking gas cap for the Ram. It's expensive in my opinion, but it's an option.
Here
Bluesurf
Here
I'm very happy with Geno's locking cap. I'm stunned spending 70+ and no locking door or cap. I was never able to get a locking cap for my L405 Range Rover. That made me feel sour towards Land Rover too. I'm done with them. The real black eye is that in the EU they all lock.
Biesty
SE Wisconsin
Here
Thanks for posting a solution to this. I don't understand why people have to criticize a posters request (but he did ask for opinions so maybe he welcomed it). But seriously, if you don't think it is necessary then just don't respond. If you see a flaw in the request that makes sense to respond ... like suggesting someone might just puncture your plastic gas tank. I get that.
A previous vehicle I owned had a locking door with a tab on the edge of the door with a slot in the tab. The fuel door locked and unlocked with the doors. When locked an electric motor moved a locking lever into the tab slot thus not allowing the door to be opened. The locking lever was attached to a mechanical cable that went to the trunk and was attached to a pull arm. If the electronics failed you could use the pull arm to unlock the fuel door. Perfect flawless design and very easy to implement. Note, the pull arm for the truck could be inside the cab instead of the trunk.
I do agree that this is a big miss on the design of the truck as it is all about deterrence. Nothing is fool proof but why not make it as difficult as possible.
