Darksteel165
As the title says.
My tire diameter was incorrect from the factory and in turn my speed and milage I accrued was off.
I only found out when I checked the tire size (I am running factory 22s Pirellis on a 2022 Limited at factory 36 psi).
It was set from the factory as 2500mm.
The calculator online for tire diameter shows 285/45R22 as 2560mm
My actual diameter that provides accurate speed is around 2523 (confirmed with GPS speed tracking).
Not only does this affect my speed readout, I accrued less logical miles, but also made my truck even by hand calculations get worse MPG (obviously this doesn't change my actual MPG but doesn't allow me to really know what it is).
I wonder how many other folks have the wrong size set and are seeming getting better OR worse MPG because they had an incorrect measurement\value.
