Which tow hitch would fit?
Viking42
Hello,
My 2019 Laramie was ordered without tow hitch
I'm looking to add one
In dont think this this part would fit
as i already seem to have the Bar:
But then its unclear which part i'm missing, how to fit the square reciever?
Bt10
MI
I assume that bar has to be removed and an actual hitch put in it's place. I'm sure the standard mopar or aftermarket hitch will fit in it's place, nothing special. Sad Ram spends the money to develop that bar without just using the hitch...
CatDaddy66
Try your local u-haul dealer, they're usually pretty reasonable
ProjectsInMotion
It looks like the bar you have supports putting a tow ball in the rear bumper. Like Bt10 said, the Mopar hitch should completely replace that bar.
xspeedy
Go look at a truck on the dealer lot or showroom with the receiver. My truck has the tubular bit that sits laterally so I think you just need to bolt on a receiver. Do you have the wiring hookups?
Richard320
That should be the part. The existing cross bar gets removed.
xspeedy
Wow, so the whole thing gets swapped out. Might want to find a wrecked one at a salvage yard you can pull this from.
xspeedy
I’m bored. It looks like the genuine part is all one piece as mentioned above, at around $250 before shipping. The PN for the DT RAM is 82215222AD, but confirm with your VIN.
Or you can save by adding a third party one that bolts onto the tubular part you have. That seems to around $100.
bigdodge
Happy Ram Owner
Hello,
just curious what does your build sheet say?
Hawkshot99
23RAM
Canada
