I see I was wrong about the EPA being the one who made the law, because they came around in 1970, but it was environmental law.
When did PCV valves become mandatory?
In California, the PCV valve was mandatory on all new vehicles for
1961. By 1964, the majority of vehicles sold in the U.S. had one as standard equipment. It became mandatory on all vehicles in 1967.
I never said the engine should have positive pressure, the system is to remove positive pressure. They could have called it the Remove Positve Crankcase Pressure Valve. The PCV valve IS there to keep the engine running, when sucking engine gasses, because if you connect the hose directly to the valve cover, the engine will not stay running. It regulates vacuum loss. I wasn't saying that's the only thing keeping the engine running, but something has to restrict that vacuum loss. The vacuum closes the PCV. They will rattle around, with no vacuum, they rattle around with no vacuum, and suck shut with vacuum. The bottom opening at the valve cover is always open, the part that closes, is at the hose end. Try sucking on the hose end of a removed PCV valve.
