Hdmlnium1
91 octane for me..
Bill
Bill
93 is cheaper then 89 waaaaaat. I’ll have to check that out in my area
Do you expect more ignition problems under the load of towing?
I can say that I'm enjoying not being required to buy premium fuel with my new truck. Filled up the 33 gallon tank with mid-grade (87 octane), 25.7 gallons. My previous vehicle had a total capacity of 26 gallons and my total expense was under $70. The station I often uses cuts off at $75 when you pay at the pump, and I usually had to start another transaction to completely fill up the Mercedes.
At some point after break in, I'll see how well the truck runs on regular.
It would probably be more useful if we referred to which grade of fuel we were using. Octane numbers don't really translate from one location to another.
If I say 87 Octane, what does that make you think? Regular or Mid grade? If I mention 85 Octane (regular here), do you even have that as an option? People talk about 93 Octane, and that's not an option here.
The idea that "Octane is Octane" is not relative to things like elevation. The grades are more suited to the stability challenges in the location where they are sold.
If I'm referring to an octane number here in Colorado, it doesn't mean jack to someone in a lower and warmer area of the country. The US is a big place covering a lot of different conditions. Alaska isn't Florida. I can't find 89 here, so I guess I'm out of luck.The use of 89 octane “Plus” gasoline is recommended for optimum performance and fuel economy.
From the owners manual:
...but feel free to talk numbers without any other relative information.
The reason I've been discussing the relativity of what the octane level means to the application is that it only relates to the stability of the gasoline and it's resistance to pre-ignition. 89 is not a magic number (neither is 87). 89 will not solve all issues with pre-ignition depending on temperature, elevation, or engine load.
What octane level does not mean is that the higher the octane number is, the more power it contains. Your engine may be able to make more effective power with a gasoline that has a higher stability, but maybe it won't. 94 octane gasoline contains just as much energy as 85.
The manual recommends 89 or Plus. If that doesn't mean anything to you, have a nice day.
