What do these do ???
Hyfire
I’ve got these on my dash. Looks like the RIGHT controls dash brightness... and the LEFT turns on overhead light???
Is this right?
I rotate these in both directions and nothing happens, anywhere. I’m confused.
Are mine broken or am I nuts?
leonandlisa
I think you are correct, you won’t be able to tell if the dash light works unless the headlights or running lights are on and it is dark out.
As for the dome light, do you have one? If you do check the bulb, if you don’t it is most likely just there because it is the same dash as many vehicles.
LaxDfns15
Memphis, TN
I thought one was for the ambient lighting and one for the dash lights. My Rebel only has one as I don't have the ambient lighting. Your manual will tell you.
Nels
Wisconsin
I think you have it right. One is for ambient lighting for sure. I also think the other is for instrument lighting. Like said above. Try them when it's dark outside.
2019REBEL
ON, Canada
The only ambient lighting in the Rebel is the light that shines into the cup holders and the dail will brighten and dim that light but won't turn it off. At least that's what it does in mine.
