Looks great. Are the mirror caps custom or is there a place to buy them to match?
It's a Mopar part
Finally got around to installing my Diode Dynamics multicolor footwell lighting in the front and back, this is how they should have come from the factory.
It's a Mopar part
Thank you sir.
I've since noticed without the suction cup method this can be a costly mod. Might just stick with the chrome covers or get the dealer to do it.
Thank you sir.
I recommend a ton of steam and then suction cup
Where'd ya put 'em? Engine bay? Under bed?
Under the cab/bed on the driver side. Right behind the auto running boards. It’s tight but everything fits.
Debadged, added black "LIMITED" inserts into the door trim, painted center wheel cap to match dark spokes, added tailgate seal to keep water out with Retrax Pro cover. Also added a metal shifter plate and a Ram start button cover. Getting paint protection film for the front bumper installed on the 13th.
Where did you get that shifter plate?
Good idea on the PPF!
Washed my truck for the first time since before the holidays. Last time I washed I got lazy and just used the self service soapy water spray then rinsed and left without drying (raining as usual in WA) so now I have little water spots all over. I’ll have to find a way to get them off without impacting the ceramic coating. 912872A4-8901-4488-BE33-F91450F347D9.jpeg
Installed the VLeds license plate reverse light
A little help, if you please. Did you tap into a reverse light in one of the taillights? If so, did you use supplied VLeds wiring and into what color wires did you tap? Did you get any warning lights after the tap? A lot of questions, I know, but would prefer not to cause myself issues do to my ignorance. Thanks for any help you can give. It was your post that made me decide to take the leap.
Installed weather Tech hard tonneau cover and weathertech mats. My older ram had the Bakflip cover. Love the weathertech SO much more.View attachment 43186
I got the same tonneau but I have a Ram Box on my ‘19 Limited and there is a gap between the tail gate and the Ram Box that’s allowing rain to get in from each corner of the tail gate. Is anyone seeing anything similar?
Pretty sure there was a similar issue in another thread. Not sure where it was. I don't think any cover will make a difference. Someone applied some foam to keep the water out.
Today stopped by a local shop and had the front windows tinted to match the rear windows with an 18% tint. Also got to do some rim shopping and i am just about ready to pull the trigger on some 20x10 -18 offset fuel blitz's with 34" (295/60) nitto ridge grapplers. Also switched all of the interior light bulbs to Led's as well. They are brighter but not as much as I was hoping for. Overall a good day!!!!
