Got rid of some chrome that seemed out of place to me with Night Edition option.
Engine oil/filter change using the WIX filter equivalent to the SRT filter
For those running the SRT filter like me, the WIX 57063 appears to be identical, minus the SRT/Mopar branding. It's only a $1 cheaper, so not a huge savings, but there have been times when I have found the SRT filter out of stock on Amazon, which is cheapest place to buy. New WIX filter vs old SRT filter. Both made in Poland. The only place the wix filter even has WIX branding is in the box. The filter itself is just labeled Mann+Hummel as shown. Which is who actually makes it. See pics below
PXL_20250309_173135715.jpgPXL_20250309_173144308.jpgPXL_20250309_173158125.jpgPXL_20250309_173228545.jpgPXL_20250309_173232228.jpgPXL_20250309_173359803.jpgPXL_20250309_173415981.jpgPXL_20250309_173423828.jpg
Did transmission fluid change and installed the PPE pan. If you are planning on doing this, few tips based on my experience today. I remove the three nuts from transmission mount into cross member and jacked the rear of transmission up by the transfer case vs trying to drop exhaust. You will need to do this in order to get the 10mm Allen wrench on the factory drain plug(if you have one). Unless your factory gasket is hard and brittle there is no reason to replace it. Mine was still very pliable, and the PPE pan is designed to use the factory o-ring style gasket. Just be careful removing it from the factory pan. And it will push right into the PPE pan.
For the factory bushings/flange collars in the bolt holes. The instructions clearly state to use them in the PPE pan. And they should be used as it will prevent you from over torquing the pan and crushing the gasket and damaging it. I used a 5/16" deep socket and they easily tapped out of the stock pan with light taps from a hammer. They pushed right into the PPE pan. Didn't need to use a hammer. They also help center the gasket in the holes. The instructions say to install the collars the same time as putting the bolts in, but they will push into the pan holes and stay. Will make it easier to get the bolts in doing it first as well. After tightening the pan, lowered the jack and the transmission mount bolts dropped right back into the cross member.
Going to start adding fluid now. Will report back with difficulty of that later.
Fluid filled. Might be a little low because I was stupid and shut the truck off before getting fill plug installed, but it was rear high with the way I had rear axle jacked up. Not sure about other bottles of fluid, but I went with Liqui Moly 1800 which meets ZF specs for the 8hp70. These bottles come with tubes built in that you can pull out after you take lid off. Still make s little mess trying to get bottle positions and tube shover into the fill hole, but not too bad. You start by putting bottle in top first facing the rear of the truck over the exhaust. Once you get the back of bottle clear of cat, you push the back up and forward over top of the oxygen sensor. Then the fun part is getting the tube into the fill hole while fluid tries to run out. Initial 5 bottles before I started the truck wasn't too bad as exhaust was cold and I was able to use my finger to plug end of tube until I got it right to the fill hole. Once I put the gloves in, that didn't work too well, so lost some fluid. Probably only an ounce total out of all 7 bottles. And for working around the hot exhaust, I just put in my welding gloves. Took about 6.5 liters of fluid. I ordered 8 to be safe. PXL_20250309_211900816.jpgPXL_20250309_211904331.MP.jpgPXL_20250309_211922576.jpgPXL_20250309_212000983.jpgPXL_20250309_212002630.jpg
Installed a cheap tonneau cover, I guess a little too cheap. They got the front clamps at the back end of the trifold front section, not the front corners of the section. So, the front is sprung up. Oh well hopefully keeps the luggage dry.
My baby is desperately in need of some TLC. It's actually gotten to be quite embarrassing.
I hope to have some time once I submit my dissertation at the end of this month.
I feel you. My truck is disgusting as well. One daughter in competition cheer and picking up baseball at the end of the month. Older daughter does travel softball. So between practice, lessons, competitions, tournaments and then all my other adult obligations my truck has fell to the way side. I keep saying I'll get to it one day but one day never comes lol.
