boogielander
- Jun 29, 2022
im praying for you!just found this so hopefully it does the trick
Where did you get power from? Fuse box or tap into the wire harness?Put my amber grill lights in.
I saw that comment on them but decided to give them a chance because I felt it would give me some more adjustability than the fix bracket from diode dynamics.Good luck with the roll bar mounts. Had a set in mine initially and they had a piece of foam tape that was supposed to help hold them in place. Lasted a couple months, then they loosened up. Bought the Diode Dynamics brackets that bolt on using one of the lower plastic trim bolts. Those worked so much better
It‘s definitely something.
Not really good for us up here is BC. No snow pack means less moisture, dryer conditions and more forest fires!
The last few years have been brutal up here for that.
With what you put your truck through REGULARLY, I would never have pegged you as one who would be concerned about a few measley brush bristles.View attachment 173976
so I went to the coin-op to rinse the truck... took $10 with just pressure water on the outside and wheel well only; I couldn't get enough angle to rinse the underside. I never use the brush... might as well use sandpaper if using brush.
needless to say, the coin-op owner is probably not too thrilled about earning my $10
Normally I do the wash at home but I don't want to deal with the mud lol
Im in Texas also, and am a bit of a gun guy. Any sale or purchase of a firearm via private party is done at the police station.Years ago I was selling a car stereo on one of those sell sites. I was messaging with the individual that was interested about meeting up for the sale. I told him I would meet him at the police department that was not very far from his house. He straight up refused stating that he will not meet at a police station. RED FLAGS! I told him I was no longer interested in selling it to him.
Do you like those Deezee bed tie downs? And how does the rail attach to the tie downs? Been humming and haaing about how I want to do additional storage in the bed. I was honestly just thinking about getting a pair of the tie downs to put in the middle of the truck so I have tie down points there. There's a set on Amazon in their warehouse for 1/3 the reg price, but it doesn't come with hardware. I've already got a nutzert tool and M6 nutserts that I could use. Just need to make up my damned mind. LMAOFinally figured out a better way to store our sticks in the truck bed with some Husky heavy duty hooks attached to my Deezee Hex rails.
How is the Bison holding up after a couple years?Stock Night Edition Limited wheels.
How is the Bison holding up after a couple years?My Bison Trifold Flipback Hard Surface Tonneau Cover I ordered showed up and I got it installed today. Very similar to the Bakflip Tonneau Cover I had on but you could tell the quality is better AND it doesn’t leak!
The bonus was it was almost 1/2 the price of the Bakflip one. I like it!
No leaks or issues with operation, however, I had one small issue with the panel closest to the tailgate. A couple of small bubbles appeared on the surface and only when it got super hot in the summer. The top metal skin separated.How is the Bison holding up after a couple years?
I used one of those Fuse Tap things and went into a circuit that is ignition powered. Can’t remember the exact fuse number but F somethingWhere did you get power from? Fuse box or tap into the wire harness?
Came out nice!Had a RC 3.5” lift installed on Tuesday and had Nitto Ridge Grappler 285/65/R20s installed on my factory rims today. Then I used AlfaOBD to set the Speedo…
Thank you. It would have been a lot easier to do the exhaust if I had done the lift first!Came out nice!
