What amount of rake should I do?
Got the 1” Motofab spacers installed. I love the way she sits now. Thank you everyone!
Rear spacer mess with your ride at all? Put on Eibach front struts at 1.8 setting, gave me 2+ so passenger side is nearly .25 higher than rear.
Mine has been great with the airbag/spacer combo. My dad got a new Titan XD and commented that he's jealous of the ride of my truck. The coils compress more than leaf springs, but the ride quality is worth it.
I did the Motofab 2/1.5 kit. I love it. It's perfect in my mind. Obviously it eliminates 0.5" of the factory rake, but it still leaves rake which is what you want. When I haul and tow I don't want headlights shining into the stratosphere. I also don't want to lose 25% of my MPG because air is blasting up under the chassis of the truck. Need to have the nose slightly down on a pickup when it's unloaded for it to function correctly as a truck.
Hey, this truck looks great. I'm relatively new to the idea of lifting/leveling and this is exactly what I would be going for (mild lift/level, mildly larger tires), as my truck (2020 1500 big horn crew cab ecodiesel 4x4) still needs to fulfill my daily work/family usage without negative effects on MPG or ride quality. What are the specs for these tires, and, have you had any issues with the UCAs, rubbing, etc?
Newbie here, I appreciate any info you can share!
I assume you mean from post #3? Those are the 20x9 wheels from the Built To Serve edition trucks, wrapped in 35x11.50R20 Falken Wildpeak R/T tires. No rubbing or clearance issues at all, but it was pretty close at the mud flaps on the front when I would steer sharply. Worked great. I even took the truck off road with no issues.
