I anticipate taking things slowly. There will be two pallets (one on each truck). Any concerns to long-term affects to the suspension?
IF...you can get the pallet loaded to the front of the bed near the cab....maybe not.
IF they load it right over the axle...probably not.
IF they load it at the back by the tailgate...it technically counts as tongue weight and you could have some issues. TW capacity is 1100 to 1300 depending in who you ask.
2900lbs is probably nearly twice your payload.
Say we believe the wise tale that you have 8000lbs GVWR. And you got an avg payload...so your truck weighs 5600lbs. So 2400lbs til you get to this magical number. Your 500lbs more. Plus you do not have a driver yet.
So. This sounding like a good idea so far?
5600...means you got 2240 lbs on the rear axle already. 4100 gross rating. Your at 5140...at 1040 lbs over axle rating...still sound like a good idea
But people claim they do it every day
