I don't have a sunroof. I think it is getting in through the firewall or fender area.You can ping ramcares on here and see if they can help. Mine ended up being cloggged lines for the sunroof and the 3rd brake light gasket.
Sent from my SM-G781U1 using Tapatalk
Thanks everyone for your posts. It turns out that after 4 failed attempts to repair the leak FCA finally agreed to accept a surrender of the vehicle which I could not be happier with. If anyone is going through this issue or any other similiar issue except nothing but the resolution of a surrender. During this process I have had the worst customer care from the dealership and FCA. FCA insulates themselves, deflects and down plays every concern you have. The negative out of this deal is FCA will not supply a loaner vehicle while my 2021 Ram is being built even though this will be my 3rd consecutive Ram, so I will be without a vehicle for about 6-8 weeks at a minimum. FCA does not care nor provide minimum customer service. Hopefully no one has to go through what I did for the proper outcome for a similar concern.
I guess I'm about to ride this fun train now too. I bought a used 'certified' 2020 rebel last week and the driver side carpet was wet. I brought it in 2 days ago and got it back in a day. They said that the drain valve on the driver side of the sunroof was clogged. They unclogged it and preformed a leak test and it was all set. Went outside the AM and the carpet was wet... odd, it didn't rain at all last night.
I miss my 2012.
I had a leak in the same area. I posted a video of the leak. You can compare it to your leak to see if it’s coming from the same place:I thought mine was all set, I went to the carwash last night for the first time in this truck (have had it since Oct) and the driver side carpet is soaked again. Its also under 30 out so the carpet was frozen solid. Trying it out today with a heater and I have no idea where to go from here. Last time it was at the dealer they "left it under running water for 2 hours" and couldn't find a leak.
Does anyone actually know how to find the drain lines on these Gen5s? The Gen4s you could see them but I can't see the front ones at all up in the pano-sunroof.
Add Me to the List: Water Leaking
5/19 build. I was hoping that by ordering late I could avoid some of these problems. I guess the factory still hasn't fixed the water leak problem. However, everything else works, and the AC is more than adequate on my Ram! Showed the Service Writer the video. She wants me to show the video...5thgenrams.com
Gerry
I took mine in for this same problem about two years ago. It sat in holding so long waiting to be looked at (all good though, i was in a free rental) that is started to have mildew smell. I was able to get the repair done that it recommends and also have the carpet replaced.I have a 2020 Dodge Ram 1500 Laramie quad cab, 3200 miles. Carpeting is soaked only on the drivers side front. I have an appointment with the dealership tomorrow. I found a TSB (which I attached) on this issue and was wondering if anyone has an experience with them performing repairs in the TSB. I am pretty nervous about them removing the fender. Any input would be greatly appreciated.
The STAR article that says to epoxy the seam? I might just try this myself next week. Super frustrating.... I brought the article printed out to the dealer and they said they couldn't find any leak.I took mine in for this same problem about two years ago. It sat in holding so long waiting to be looked at (all good though, i was in a free rental) that is started to have mildew smell. I was able to get the repair done that it recommends and also have the carpet replaced.
