Ninja Rooster
- Feb 25, 2024
Hello; I’ve read through some of the water leak posts and will be checking some things on sun roof drainage.
I have a 2019 Ram 3500 Laramie with 27k miles. Out of warranty on time. I had water entering the third brake light and instead of going with the foam factory seal; I went with another seal that was recommended on forums. Seemed to have worked for a bit.
Yesterday I got in the truck to go get lumber and water poured out of the interior light in the headliner. It is the lowest point of the headliner and water from the rear window and 3rd brake light cannot get there without traveling up 2-3 inches. I believe only the sunroof can let water into this area. Here is a screenshot of what I found. I am going to try and replace the seal myself. Question is; my roof seems to press in extremely easy in the very center. Is this normal for the crap they’re producing now or am I missing a roof support?
Yes I know it’s dirty. It’s being detailed and ceramic coated next weekend if I fix the leak.
