Vent settings
Rebel3326
Has anyone else noticed when going thru the vent settings that when floor only is selected it blows out the floor and thru defrost? Then when selecting floor/ defrost it doesn't change from floor only except maybe blow a lil harder on the defrost.
Just wondering if anyone else has or had this happen.
19 rebel 4x4 crew cab.
Rebel3326
I haven't particularly noticed that on my pickup, but leaking some off to defrost while on heat has been pretty standard for decades.
It's not just leaking off a lil ... it comes out the defrost full blast... it pretty much same as selecting floor and defrost... maybe slightly harder out the defrost but a negligible difference.
Does it on heat or ac when floor only is selected.
Rebel3326
Working as designed. Says it will blow air to defrost in those modes. Page 79 in the my owner's manual.
It says a slight amount, what im experiencing is not a slight amount by any means. Placing my hand in front of the side defrost vents it blows the same amount when switching between floor only and floor/ defrost.
2019REBEL
ON, Canada
Mine blows a fair amount too, my 2014 Outdoorsman did too. Not really worried about it.
echristi
I have a large amount coming out of the top of the side vents when on foot only. I assume to window defrost - so much that it is uncomfortable and makes it feel much colder than usual, and requires a different heat setting. I am not happy about this - I will see what the dealership says, maybe there is an adjustment that can be made to make it less. I agree - it is not a slight amount
jmt8706
Michigan
Add me to the list. More of a curiosity situation for me, not really an annoyance.
mikeru82
The Palouse
Old thread but still relevant. I mostly keep my HVAC on Auto, so I haven't noticed how it behaves. Now I'm curious though.
Gatorfan08
My 2021 ram 1500 bighorn is doing the same thing there is a significant amount of air that comes out the defrost vent when set to floor
mcat79
I just found this thread, this as been one of my biggest annoyances. My side window defrosters just blow out fire while I drive. The only way to resolve is to shut off the climate control or manually turn the fan off, but that affects the rest of the cabin temp.
