Realtruck
- Jul 2, 2021
Looking to enhance your truck's style and functionality? We've got the perfect solution!
Upgrade your truck's look and functionality with our Electric Running Boards:
Key Features:
Automatic Deploy and Retract: No more awkward climbing – they extend and retract automatically.
Enhanced Safety: Wide, non-slip stepping surface for secure footing.
Durable Construction: Built to last, even in tough conditions.
In-Stock & Ready to Ship: Our electric running boards are available now for quick delivery.
AMP Research Power Step
AMP Research is leading the industry for electric running boards, offering you an exceptional product that is built with your truck, Jeep, or SUV in mind.
- The original electric-powered running board
- Corrosion-resistant die-cast aluminum construction with military-grade black PTFE coating
- 6-inch wide, cab-length steps automatically deploys and retracts
- Low-profile, integrated LED courtesy lights
- Includes vehicle-specific installation guide and mount kit.
- Most applications include patented Plug-N-Play module for easy installation.
- Includes a 5-year/60,000-mile warranty.
At RealTruck, our running boards are built to last and designed for easy installation, as well as compatible with various truck makes and models. They offer:
☑ Style and functionality
☑ Enhanced safety
☑ Easy installation
N-Fab Nerf Step RS
- Crafted from a sturdy steel tubing and protected by a dual layer powder-coating to form one stylish set of steps! The protective coating starts with an e-coat base-coating and then meticulously finished with a textured black powder-coating and fitted with plastic end caps to protect the steps from corrosion.
- With these steps, you and your passengers will be able to securely step into your truck with ease on the 4.75" wide die-punched step surface.
- The Nerf Step RS will add functionality to your ride as well as style with the rugged look of the textured hoop steps. N-Fab backs these steps with a limited lifetime warranty.
- Rebate alert: Rebate for Free Husky Liners WeatherBeater Front Floor Liners when you purchase N-Fab Nerf RS Steps, now til 9/27/2023
N-Fab Black Cab Length Nerf Bars
- These bars are available in two different finishes for most applications. Available in Gloss Black or a Textured Black Finish for a smooth, matte look.
- These steps are built of a heavy gauge 3-inch rail that sits up close to protect your truck's body. It's the perfect fit with superior strength and protection.
- The N-Fab Cab Length Nerf Bars have a patented hoop step design which offers a lower stepping surface than most nerf bars in the industry.
N-Fab ROAN Running Boards
- The ROAN Running Boards are the latest series of side steps from N-Fab. This rugged, next-level design provides an ultra-tough appearance unlike any other running board.
- The N-Fab ROAN Running Boards are constructed from 1.75" heavy-duty perimeter tubing with a 12-ga steel top plate capable of supporting up to 475 lbs. These boards feature an extra-large 5.5" raised louvered stepping surface and have bolt-on step pads that are removable for customization.
- Additionally, the N-Fab ROAN Running Boards will come with a mounting system that allows inboard/outboard adjustability and delivers superior fitment. N-Fab also warrants the craftmanship of these running boards for a lifetime and 5-years on the finish.
Go Rhino RB20 Slim Running Boards
- Constructed from galvanized 16-gauge steel to help resist corrosion.
- Available in either textured powder-coat or protective bedliner coating
- 5.5” wide stepping surface with rugged perforations that allow dirt and debris to fall through.
- Installs directly to the rocker panel with a vehicle specific mounting kit and instructions.
- Easy, bolt-on application that is drill free.
- Includes a limited 5-year warranty.
Go Rhino Vertex V3 Sidesteps
These 5” oval nerf bars will add an aggressive look, perfect for both on and off-road.
- Constructed from light-weight aluminum with a textured black powder-coat finish for a rust and corrosion resistant step.
- 5” wide polymer tire-tread step pads offer a sure step.
- Extruded aluminum core holds up to 300 lbs. per step pad (600 lbs. per side)
- Rocker panel mount that includes vehicle specific hardware and brackets for a straight-forward, no-drill installation.
Ready to order or have questions? Send us a private message or email us directly at [email protected], and our forum team will assist you promptly. Elevate your truck today with RealTruck!
Upgrade your ride now!
