Do you have a picture you could share. Thanks
Yep....the price you pay for a better looking truckIs anyone seeing a significant drop in MPG’s after installing the lift?
Exactly what he said!Yep....the price you pay for a better looking truck![]()
I’m going to do the lift and add toyo at 3’s in 275/60/20, tires aren’t set in stone yet I may go with something else. How bad are we talking......Exactly what he said!
I dropped about 3mpg with 35sI’m going to do the lift and add toyo at 3’s in 275/60/20, tires aren’t set in stone yet I may go with something else. How bad are we talking......
Same as Jeffjad. I'm running 295/70/18 which is 34.3 tall. The lift and weight of the new wheels and tires is a mpg killer.I’m going to do the lift and add toyo at 3’s in 275/60/20, tires aren’t set in stone yet I may go with something else. How bad are we talking......
If you're asking me it's between 80 1/4 and 80 1/2 inches. That's sitting in my garage on level ground with 44psi in the tires.Do you mind telling me what your overall height is. Ground to the top of your sharkfin. I am in DC so height is a big deal for me.
eproulx38If you're asking me it's between 80 1/4 and 80 1/2 inches. That's sitting in my garage on level ground with 44psi in the tires.
I went the ORP route because I wanted to stay with all mopar parts just in case I have any warranty issues. I've also heard top hats can be squeaky sometimes.So I have a question for the folks who did the ORP springs for the level. Not sure if some of the information I am about to state is correct or not, so will be happy to be corrected.
I have the AC kit installed, so there is no spacer, am I correct in the assumption that it is achieving its front lift in much the same way a bilstein shock would with just moving the seat up? If that is the case, I am wondering why did you choose the ORP springs vs just doing an 1.5 inch spacer like the top hat spacer in the RL 3.5? Would this not be very similar to the folks who are doing the combination of RL and bilstein shocks (where the bilstein shock is set at 4 with the 1.5 top hate spacer)? Is the idea that this ride quality would be worse than the ORP springs?
looks nice, you don't have the ORP springs right?Hi all I just posted mine in another thread but 295/65R20 fit on stock wheels with only a slight mudflap trim. I have the AC kit that was just installed.
Shouldn’t matter if you are putting bags in the back.Got it, I’ll be doing some timber grove bags as well in the back for leveling the rear back up. I would like to see the fender measurements of the revised kit. If there’s still a little rake with the kit I’m good with it, just didn’t want to go full level because of towing.
