Haven’t seen anything from Mopar, but these are available.Does any one know if there is a Mopar Part# or a kit for an Under Hood Engine Light? It seems the 5th Gen's do not have one.....
Thank You!!Haven’t seen anything from Mopar, but these are available.
KC HiLiTES 355 Cyclone LED Universal 2-Light Under Hood Wiring Kit https://a.co/d/i5WlSi8
The switch is to disable remote start. Hood opens, engine dies. Won't remote start if open.My 2023 Big Horn seems to have a hood switch, but there are no lights under the hood. I am guessing the switch is only used to tell you the hood is open, and/or part of the anti-theft system. Anyone know if that switch on the left side of the radiator shroud can be used to trigger an LED light?
just hardwire it to battery and then body ground it.Where did you tap into a power wire?
That's a really nice install. I assume the lights are screwed into support members on the inside of the hood?I installed the KC light that RAMomkey mentioned in post #2. I connected to an Aux Switch for power. Here's pics
Yes, the insulation is fastened with the plastic plugs at those sites. I just used a metal screw that fit the plug's holesThat's a really nice install. I assume the lights are screwed into support members on the inside of the hood?
The LED should be pretty light. Surprised you wanted to use a metal screw. Did you think a plastic-type insert would not hold it?Yes, the insulation is fastened with the plastic plugs at those sites. I just used a metal screw that fit the plug's holes
IMHO not long enough and a screw in the hand is better than a plug at Napa...The LED should be pretty light. Surprised you wanted to use a metal screw. Did you think a plastic-type insert would not hold it?
Yes, I pulled the insert and used the hole the insert used to screw the light downI don't recall if there was a solid tree plug there or an insert with a pull out plug. In either case, a screw into an insert works. Unsure if that's what John's referring to.
A plastic insert would probably be too big for the light's mounting hole. I used what I had, a #10 or 12 metal screw, maybe bigger, can't remember.The LED should be pretty light. Surprised you wanted to use a metal screw. Did you think a plastic-type insert would not hold it?
