Sigfla
- Dec 29, 2023
So I was fiddling around in the driveway repeatedly soft resetting my radio. I would get oil pressure or coolant pressure back then nothing then one would be stable for several cycles then all came back. A hard factory reset brings them all back but once you shut off and restart the engine you may or may not lose them. Seems to me this is a software startup issue. Something is not keeping a setting it’s supposed to on normal on/off of the ignition. I have found my WiFi sometimes does the same. I have to reset the radio in order to turn it on bc the touchscreen will not register my press nor will the radio sometimes keep the WiFi setting always on.
