ScubaZ66
- Oct 8, 2021
Update: Dealer contacted Chrysler and tried to order a new radio. Chrysler explained Dealership could not order a new radio until the Service Department did a hard reset of the system and a couple other test. I believe one test was to complete any OTA Updates such as the latest S26.17 software update. Dealer ran all the tests and still couldn't get the TPMS to function properly. According to the Chrysler Engineers a Selectable TPMS doesn't exists on the UConnect5 System (Even though mine has functioned since Jan 2022). The Service Manager is a friend of mine so he invited me into the shop area to review and discuss any possible fixes. He used his cell phone and took some screen shots showing where the driver can Select a different Tire Pressure for each of the 4 tires and save that information in memory. He also took pictures of the Instrument Cluster showing the correct selected tire pressure as well as (after about 15-20 seconds) the screen showing low tire pressure for 3 of the 4 tires although all four tires have the same pressure. When the system started malfunctioning back in Oct 2022 only one of the 4 tires were showing bad tire pressure. As time progressed 2 then 3 have shown bad tire pressures. He's going to provide these pictures to the Chrysler Engineers and get a better understanding of how this system actually works.
We also discussed how the TPMS was designed to work and he mentioned a RF box located behind the rear seat that he believes picks up the TPM Valves from each of the 4 tires and relays this information to the UConnect5 System to display the Tire Pressures in the Cluster on the Dash. In theory this seems to make sense. He has ordered the RF box (I'm assuming RF stands for Radio or Relay Frequency) and will schedule me a date/time for installation.
I also learned something new. The Touch Screen is just that, a touchscreen where the driver programs the system and it is seperate from the actual radio. The actual Radio itself is just a box located in a different location.
I'll update again once the RF Box is replaced to see if this fixes the TPMS.
