Transmission Oil change and other fluid changes.
Question, is it required to replace the pan? If so, I’m assuming because the drain plug had a pipe that sticks a few inches above the bottom of the pan and doesn’t design the bottom of it, if so. Plus the filter change.
Yes, because the filter is part of the pan itself. You can either replace with an OEM style or get a PPE pan with a replaceable filter. I did PPE because I'm hoping to keep this truck for lots of miles.
I had the transmission serviced by the dealer at 30K miles. I bought the truck used and it had 15K miles of towing recorded, with air bags installed, which tells me he was towing more than likely heavier than the rating. The dealer agreed with why reasoning.
man, some thoughts here...
I have a 2019 1500 Bighorn I use for towing a camper - Texas to West Virginia, Wyoming, Colorado, etc. Got the truck w/ 17k used from Enterprise. Also, one trip up the Raton Pass - the RPM's and temps were getting up there...
I'm out on summer trp with the camper - truck rubns fine, temps all fine. BUT I am dealing with the 4x4 actuator issue. THAT'S what led me down the rabbit hole and got me here...
My 4wd doesn't work, saw the actuator fix, figured I could do it, but how to relace the fluid? Hmmm, maybe I should check the tran fluid and differentials. Service schedule is 60k. Ooops, I'm at 64k... 65 by the time I'm home...
I would love to do this myself, Seen the PPE post here and watched many videos. Not sure I have the time or patience in case I screwed anything up in the process OR that I'd be the best judge of drained fluid condition, lookig for debris in the old fluid I'm replacing.
I have a great mechanic, but he may be a bit busy...
On the differential actuator swap, very little fluid will drip out. If you park the truck on a slight upward incline (or even just on flat ground) you'll likely be fine without refilling.
I just serviced both differentials and the transfer case on my truck (62k miles). It's the easiest service I've done on a vehicle (buy the diff oil they sell in the pouch).
Its time to change diffs, transfer case and transmission fluids. I can't say about 4x4, but if its auto 4X4, there is a clutch involved and the oil is expensive.
You can find cheap oil elsewhere, no need to buy the mopar stuff. HPL for one, has oil that works in the auto TCase.
Ya, I actually researched the TC oil and have a few samples of different oils to compare, but I had to buy the OE oil to compare with the others, so I used it first.
Got the actuator and was about to start the swap - seems easy enough, BUT (my PPE tran-pan upgrade sent me down the rabbit hole of making sure I got the filter and the gasket) I realized I don't have a gasket - the actuator didn't come with a new one...
None of the videos I've seen mention one, but feel like it's an obvious thin to replace with a new actuator. OR do I consider that the old one may be fine to use?...
I just put it on. No issues or leaks.
I’m doing my transfer case soon I see the owners manual says
We recommend you use MOPAR Transfer Case Lubricant for Borg Warner
Warner 44-44 and 44-45. Transfer case 48.11 active in demand 2 speed r case w/ auto 4wd. I’m looking at amsoil and not sure how many cases or packs I need to get of the gear oil?
1.4-1.8 liters …..
1.4-1.8 liters …..
I bought two quarts of fluid for the transfer case and had just a little bit leftover.
How can I tell what transfer case I have? I see there are two for these model years.
  • 2019 - 2024 Ram 1500 New 5th Gen transfer case fluid fill capacity is 1.3 liters (1.8 quarts) for BorgWarner 48-11 or 48-12 transfer case.
I also read this on blauparts site.
  • 2011-2024 Ram 1500 transfer fluid change for 4WD models with BorgWarner BW44 or BW48 transfer case.
I do have a 4WD.
I do have a 4WD.
Go to one of many sites that run your vin ( I am sure someone on here will post one ) and you can pull your build sheet. It will list all that you need.
I checked the build sheet site and this is all it says for transfer case.
ELEC SHIFT ON DEMAND TRANSFER CASE
Hello. I have changed the transmission fluid every 10K since new by drain/refill. Is there any such thing as changing it too often? The reason I ask is my father claims I will kill my trans cause the fluid contains inportant clutch material that I am getting rid of when I change the fluid. I have also changed the silverados fluid quite often as apposed to doing a flush. Is there any truth to if I change the fluid too much I will kill my trans. Or am I safe to change away. BTW the AVEO shift as good as it did the day I drove it off the lot with 4 miles on it.
Killing nothing but the planet and your wallet.
As posted, 30K mile trans fluid change was early, but seeing the history on the dash towing more than likely heavy. 10K mile interval is way too often and a waist of money. I was told by the service writer, 50K first fluid change then 30K after. But as long as the maintenance schedule allows is what I will follow. The biggest issue I have, you can no longer inspect the fluid, because you no longer have a dip stick.
