Train Horn Mount Locations
Smeyer52
Hey everyone, recently bought a used 2019 Ram Limited. It's replacing my old 2013 Ram, anyways my old Ram I had bed side mounted tool box, which I mounted my Nathan Airchine K3LA underneath with everything to run it inside the tool box. My new truck came with a soft tonau cover and I like having it on so I decided to go with a tool chest instead so I can keep the cover.
That being said I have the bigger gas tank and air suspension there isn't much room to mount horns let alone an air tank. I was looking behind the front bumper and theirs 4 unused bolts near the tow hook bolts. I'm almost thinking just running an airline to the front from the tool chest but I did see some people mention getting a different intake and mounting the tank under the hood. That will be something I'll look into.
Has anyone mounted or fabricated a bracket using those 4 bolts or any other configuration to mount the horns? These horns aren't huge but also not small.
I don't plan on doing much to the truck now. I've color matched the mirrors going to wrap the chrome around the windows black. I removed the molding on the doors also. Which turned into a nightmare as it cost me 2k to fix the paint that came off with the adhesive tape. Must've got a bad factory paint job, hopefully I didn't get screwed lol. I changed our all the badges from chrome to black. And tinted everything.
So far I love the truck, can't complain though I do miss my old Ram at times but it was time for her to go. TIA
Ninety-9 SE-L
Tampa
I have a small air tank I plan to mount somewhere when I get the truck. It may just end up somewhere in the bed, but I'd prefer under the bed, if possible. That's about the only location I can think.
I'm not a fan of "Train horns" but if you're going to invest in an air horn, I always prefer a REAL trucker horn like the Hadley 29":
bucolic
New York Upstate Not the City!
Where would you mount those? On the roof or the hood :) :) ?
Whodeysrt
I mounted my Hornblasters tank and pump in my Ram box. The 6 horns are mounted behind the rear fender just past the Ram box from underneath…. The Ram box keeps the water away from the electrical components.
Malodave
Rindge NH
My Avatar shows the Nathan K5LAs on my 2008 Big Horn. I used a York 210 AC compressor mounted to the Hemi,
and two Aluminum Air Tanks mounted on the Frame Rails.
I need to move them over to the New Laramie and design brackets to mount a Sanden Compressor to the EcoDiesel Engine.
I am going to try and mount them in the same location.
Malodave
More Pix:
