You have not seen pricey until you go for a set of Nathan K5LA Airchimes.
I am waiting on the weather to get just a bit warmer and the snow to melt.
Then I can work on moving my set of Nathans from my '08 Big Horn to my
'21 Laramie Ecodiesel.
I picked up a Sanden SD7H15 Clone on Amazon for $95. I will drain the oil
and put Red Hi Temperature Grease in all the bearings. I have identified two
bolts for one of the Brackets to hold the Compressor to the Ecodiesel. I have
to see about some other mounting points as well.
I will make an Hybrid Idler Pulley for the serpentine belt to drive a regular V
Belt to the Compressor. I will try to get pictures and a write up on what I
figured out.
My '08 I designed the Brackets to mount to the Alternator and
purchased a Hybrid pulley for that off the internet.
See this Thread for Pix:
I'm looking for an air compressor to carry in the back of the truck to refill my tires after airing down for off-roading. I've read that the ones connecting directly to the truck battery terminals work better than the ones that plug into a cigarette lighter outlet. What do you think are the...
5thgenrams.com
Malodave
