Train Air Horn - button location
blacksheep37
For anyone that's installed an air or train horn, where did you put the control button?
My first choice is to avoid just connecting it to the factory horn/steering wheel control. But I also want it readily available - I don't want to be searching for a button if I'm in a situation where I need a quick blast.
Are you using all your homelink buttons?
When I had a train horn setup on my old truck, I put in a switch where I could use the steering wheel horn button for both horns. This way I could just flip the switch when I didn’t want to use the train horn.
Really like this idea - possible to get a little more information?
Careful here, some states have passed laws against having a "sound device" that is not in keeping with the vehicle. Mainly for sirens but I know a guy who had a train horn on his motorcycle (in California). He got pulled by a cop and they made him cut all the wiring right there.
It’s been quite a few years back, so I can’t remember exactly how I did it, but I had the switch where one position of the switch allowed the button to run power to the train horn and the other position ran power to the factory horn. I believe it would be a double-pole double-throw switch.
TEXAS
(d) A warning device, including a horn, may not emit an unreasonably loud or harsh sound or a whistle.
Sounds subjective to me. I never had an issue with mine, but I didn’t use them a lot. Mostly when messing with my friends/co-workers and when actually needed. I did have the switch set to the train horns when I set my alarm. That was a car alarm that NOBODY ignored. GUARANTEED! I wanted anyone trying to break into my truck to leave a DNA sample behind.
I'm a DIY and wired up my reverse lights, auxiliary reverse lights and some tail gate lights with a DPDT switch.
I don't know if this will refresh your memory on DPDT switch.
Post 364
I believe a SPDT switch would work for flipping between the 2 horns. But like you it is 5 years since I wired up these lights.
