6of36
Long story. Ordered 23 Limited Elite edition. When building, there is the option for " trailer camera wiring prep package " for $590. At the bottom of build, there is " trailer surround view camera system "for $1,095. The expensive part, is the part that goes on the trailer, with 4 cameras, harnesses, and a control module. The $590 prep, is the harness and connector on the truck. When you click prep package, the price goes up $590. As soon as you add level 1, or elite packages, it removes camera prep. Since it is basically 2 ft of wire, and the plug at the end, the salesman said, it must be part of those packages, like something else in those package caaused a different harness, including it. There is no information anywhere I can find about the system. I found one sentence in the owners manual, that says plug in 12 pin connector. There is no picture of connector, and no available Youtubes showing it. Dealer tried telling me it works through 7 pin, and the truck has it, it just won't turn on in dash, until I hook up a trailer. Lie. Now I am told the option is not available at this time, it will be late availability. If that is the case, I will wait and reorder. I really want that system, because I have to back a pontoon boat that is 8.5 ft wide, and 35 ft long from tongue to prop, into a garage. ( long Trailer for 24 ft boat, with outboard hanging off back.) Does anybody have a clue about this system? Is it possible to get the prep harness from parts and add to existing plug on truck? I want plug and play, and not cutting a harness.
