Brand new to the site so sorry in advance if this topic has been discussed. Don’t know how it couldn’t of been but I can’t seem to find out how to find it . Does anyone know if there is a way to disable traction control in 2 wheel drive without pulling f7 fuse and the ABS circuit still working ? Have the Diablo sport i3 tuner and unlocked pcm that will disable traction control till you turn truck off then when you turn the truck back on it resets back to traction control on. Can’t take an on-ramp or off ramp that is banked faster than 30 miles per hour without the truck spazzing out and applying the traction control like truck is going to start flipping end over end. Very annoying and lame. Hemi tuner guy Shawn says he can turn it off permanently but it will disable ABS circuit and wants $250. But pulling f7 fuse will produce same results. Has anyone heard of traction control being turned off in 2 wheel drive while still being able to leave the ABS on and functioning. Thanks so much any info would greatly be appreciated. Also curious if anyone else has this same issue. Truck has a 3 1/2 rough country suspension lift and air bags in the back with rough country shocks. My thought is that the pitch and roll program in the ecm that is connected to the ABS system somehow got jacked up and isn’t calibrated correctly now that the truck has been lifted. Have no idea
