TPMS
I ended up picking up the sensors off amazon through the link. Sensors are going haywire. I'm getting readings from the sensors, but they'll drop signal and I haven't had all of them read pressure at the same time. Switches from tire to tire. The seller said they need to be woken up? I thought they were plug and play for OEM? Any ideas?
If they’re truly OEM simply driving with them installed will sync them up and should present no issues.
I had issues with the first set of cheap supposed to be OEM TPMS I ordered them ordered a set from a different person and they worked perfectly.
Starting to think that’s what’s going on with mine. Anyone have a link to ones that will work?
These things read for a while then go missing. I’ve never had all of them working at one time. The tire shop said they’re sending out a signal. For some reason they’re not sending out a signal consistently.
odd. I have had mine in my wheels for about a year. Not one single issue with them.
My first set acted just like you said even though some had ordered from them and had no issues.
These were my initial ones that didn’t act right. All working randomly. https://www.ebay.com/itm/153698410883
These were the set that has worked perfectly.
Mopar 2019 Dodge RAM 1500 DT Set... https://www.amazon.com/dp/B07M5MGDMJ?ref=ppx_pop_mob_ap_share
That’s strange. The ones that works for you are the ones that I have and are randomly working for me. Did you just swap the sensors out and they started working?
Anyone have issues with aftermarket led bulbs and tpms? I do have new led headlight bulbs that I installed at the time I swapped tpms sensors. I just read that leds may cause interference
Yeah that is strange. I had multiple people tell me that the original ones synced right up for them. The amazon ones have worked now with no issues for a few months. I took all of the old ones out and gave them away when I sold my factory wheels I think and kept my original factory ones as spares.
Yep once I swapped the eBay ones out for the amazon ones they worked immediately. The eBay ones literally would read my front two, then next time in the truck read 3, then read 1, then back to 3 always random and never all 4 at one time but all of them worked at some point just never together
I’m having the exact same issue. Hopefully the new ones purchased will work.
