LRojas
- Jan 1, 2021
I have a 2019 Laramie RWD, as far as I know, the Bridgestone Dueler Alanza's are stock as well as the TMPSs. I noticed that the sensors were reading 38 psi, except for the one that had a bolt in it. I plugged the hole and aired up the tire using a manual pressure gauge to 38psi. I started the truck and noted that the tire on the TPMS showed 44psi. I checked the other tires manually and they were reading 30-31psi. I aired them all up to 38psi and now all the tires with the TPMS read 43-44psi.
Is there a way to "calibrate" the TPMS to read what the manual gauge reads?
