Sigfla
- Dec 29, 2023
Anyone know the stock TPMS range on a limited with 285/45r22’s? My stock pirelli tires show 36psi on the door placard but I want to know when the alarm will trip if over and under inflated. Can I air up to the max sidewall pressure (50psi) if I am towing a load without tripping the sensor? If I use an aftermarket E rated tire should I increase the max psi to 80 based on the max sidewall pressure?
