towing
Sobczynd
Hi All,
I've looked all over but can't find the answer. What is the weight towing capacity if I just use the ball on the bumper? I have a 2019 warlock v6. The bumper says to check the manual, but there is no information I can find.
devildodge
Moderator
Central Pennsylvania
If my sd card would load in my phone I would give you the info
Have you downloaded the full manual?
We have the link here somewhere if you haven't
devildodge
Moderator
That capacity may be more...i hate when technology will not cooperate.
I also just noticed you said warlock...wich is a 4th gen.
It might be 5000 500
Sorry, I can not get my phone to do what it should
OldMarine
while we're at it, I have a quick question. Do you guys think I need to use a WD hitch for my set up. I 'm pulling a 23 foot Jayco Hybrid style TT. Fully loaded with gear, water etc, the TT will be about 4800#...tongue weight about 400#..have a 1500 Limited 4x4. I had it out on the highway for a test run and at 65 it got a little sway..nothing crazy but i could feel it. Was wondering if just a sway bar would be ok. or go full WD? Plan on taking this set up from Mass, to Colorado later in the year. What say y'all.
