The towing trip computer does not know a 4 pin trailer is connected!
I had my first chance to try towing when I went to pick up my sled and I connected a light snowmobile trailer (4 pin connector), so I thought I'd try to see how the towing trip computer worked as I never had that option before now.
But the towing trip distance computer didn't show any elapsed time, nor distance.
I would expect the trailer to be detected and also the rear park sense to be disabled.
How does the truck know it's towing something if not by the electrical connection? I tried the tow mode off and on and it didn't make any difference. The manual doesn't say much about how to enable tow mode for the trip computer.
Our Ford Escape knows when a 4 pin trailer is connected. It will disable the rear park alert, and will even warn you if a trailer lamp fails, or the connector unseats during a trip (connector falls out while in drive or reverse).
I tried searching here also with no luck.
Thanks for any help!
Edited: It seems only a 7 pin trailer with brakes will work. The manual makes no reference to how this should work.
Trailer selection screen in setup should allow for a trailer with no brakes and have these features function properly.
